FAS2650 で「 BATTERY_LOW 」を呼び出します
Knowledge Base guidance
This article may include metadata, visibility, validation state, and related support guidance.
環境
- ONTAP 9.5P10
- FAS2650
- FAS2620
- サービスプロセッサ(SP)5.7
問題
EMSも24時間のcallhome通知を送信しますが、クリティカル状態のため20分でフェイルオーバーします。
EMSログで次のエラーが報告される
[cluster-01: env_mgr: nvmem.battery.capLowCrit:EMERGENCY]: The NVMEM battery capacity is critically low (0 cycles). To prevent data loss, the system will shut down in 20 minutes.
[cluster-01: env_mgr: nvmem.battery.fccLowCrit:EMERGENCY]: The NVMEM battery full-charge capacity is critically low (0 ). To prevent data loss, the system will shut down in 20 minutes.
[cluster-01: env_mgr: callhome.battery.failure:EMERGENCY]: Call home for BATTERY (capacity low) CRITICAL.
[cluster-01: env_mgr: callhome.battery.failure:EMERGENCY]: Call home for BATTERY (full charge capacity low) CRITICAL.
[cluster-01: statd: monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Battery remain capacity critical)
