如电池电量严重("Bat initial FCC"不可读)、请致电主页
Knowledge Base guidance
This article may include metadata, visibility, validation state, and related support guidance.
适用场景
- FAS8060
- AFF 8060
问题描述
更换主板后、ONTAP 会在启动过程中报告以下错误消息:
[Node01:nvram.battery.sensor.unreadable:EMERGENCY]: The NVRAM battery state cannot be determined because the 'Bat Initial FCC' sensor is unreadable. To prevent data loss, the system will shut down in 5 minutes.
[Node01:callhome.battery.failure:EMERGENCY]: Call home for BATTERY ('Bat Initial FCC' unreadable) CRITICAL.[nvram.hw.initFail:CRITICAL]: NVRAM hardware initialization failed: DDR DIMM is not present or failed to train.
* CRITICAL ERROR *
* NVRAM has detected errors. Ontap cleared the error. *
* Data loss is likely. *
