瞬时 AutoSupport (电池(容量低))通知消息
This article may include metadata, visibility, validation state, and related support guidance.
适用场景
- AFF A250
- 基板管理控制器(BMC)固件。15.2
问题描述
- EMS 消息
HA Group Notification from node_name (BATTERY(capacity low)) NOTICE
- 一个或两个节点报告相同的问题描述,并在几秒钟后清除:
Fri Aug 06 10:15:39 +0200 [node_name_1: env_mgr: nvmem.battery.capLowWarn:error]: The NVMEM battery capacity is below normal (5 cycles).
Fri Aug 06 10:16:39 +0200 [node_name_1: env_mgr: callhome.battery.notice:notice]: Call home for BATTERY (capacity low) NOTICE.
Fri Aug 06 10:32:49 +0200 [node_name_1: env_mgr: nvmem.battery.capNormal:notice]: The NVMEM battery capacity is normal.
Thu Aug 05 00:02:49 +0200 [node_name_2: env_mgr: nvmem.battery.capLowWarn:error]: The NVMEM battery capacity is below normal (5 cycles).
Thu Aug 05 00:03:49 +0200 [node_name_2: env_mgr: callhome.battery.notice:notice]: Call home for BATTERY (capacity low) NOTICE.
Thu Aug 05 00:32:09 +0200 [node_name_2: env_mgr: nvmem.battery.capNormal:notice]: The NVMEM battery capacity is normal.
- 未报告任何其他相关错误。
- 在 BMC/e0M 端口中可以发现大量流量。示例:
eth0 Link encap:Ethernet HWaddr D0:39:EA:47:11:31
inet addr:192.168.0.1 Bcast:192.168.0.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:539889 errors:0 dropped:277459 overruns:0 frame:0
TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:54208615 (51.6 MiB) TX bytes:624 (624.0 B)
Interrupt:32
-- interface e0M (34 days, 11 hours, 25 minutes, 25 seconds) --
RECEIVE
Total frames: 110m| Frames/second: 37 | Total bytes: 20986m
Bytes/second: 7045 | Total errors: 0 | Errors/minute: 0
Total discards: 0 | Discards/minute: 0 | Multi/broadcast: 569k
