跳转到主内容
DS2246 磁盘架风扇处于高速运行状态
i
Knowledge Base guidance
This article may include metadata, visibility, validation state, and related support guidance.
适用场景
  • AFF 系统
  • FAS 系统
  • DS2246
  • MetroCluster
问题描述
  • 为 SHELF_FAULT 和生成的AutoSupport警报 SHELF COOLING UNIT FAILED
[Node-01: statd: monitor.shelf.fault:alert]: Critical fault reported on disk storage shelf attached to channel 3a. Check fans, power supplies, disks, and temperature sensors.
[Node-01: statd: callhome.shlf.fault:error]: Call home for SHELF_FAULT
[Node-01: monitor: monitor.globalStatus.critical:EMERGENCY]: Disk shelf fault.
[Node-01: dsa_worker5: callhome.shlf.fan:EMERGENCY]: Call home for SHELF COOLING UNIT FAILED
  • environment status""显示  即使服务器机房温度正常,风扇仍以极高的速度运行
 Shelf: 10 SES device path: local access: 3a.125L103 Module type: IOM6; monitoring is active Shelf status: critical condition SES Configuration, shelf 10: logical identifier=0x500a09800385ace9 vendor identification=NETAPP product identification=DS2246 [truncated...] Cooling Unit installed element list: 1, 2, 3, 4; with error: 1, 2, 3, 4 Cooling Units by element: [1] 8000 RPM [2] 8020 RPM [3] 8000 RPM [4] 8000 RPM
已执行故障排除:
  • 磁盘架固件为最新版本
  • SP固件已升级到最新版本
  • IOM、PSU和风扇均已单独重新拔插
