控制器警示 LED 亮起,并由 SP 设置
This article may include metadata, visibility, validation state, and related support guidance.
适用于
- FAS8040
- FAS8020
- 服务处理器 (SP)
问题
- 控制器警示 LED 亮起。
- 可在以下命令输出中找到 SP 设置的。
ONTAP 集群模式
示例:
cluster::*> system controller fru led show
Node FRU Type Bay Slot State Lit By
cluster-01
controller A 1 off -
pci - 1 off -
pci - 2 off -
pci - 3 off -
pci - 4 off -
batt-nv - 1 off -
boot - 1 off -
dimm-nv - 1 off -
dimm - 1 off -
dimm - 2 off -
dimm - 3 off -
dimm - 4 off -
cluster-02
controller B 1 on SP
pci - 1 off -
pci - 2 off -
pci - 3 off -
pci - 4 off -
batt-nv - 1 off -
boot - 1 off -
dimm-nv - 1 off -
dimm - 1 off -
dimm - 2 off -
dimm - 3 off -
dimm - 4 off -
Data ONTAP 8.2 7-模式
示例:
node*> fru_led status
Controller slot B: On (lit by SP)
DIMM slot 1: Off
DIMM slot 2: Off
DIMM slot 3: Off
DIMM-NV slot 1: Off
PCI slot 1: Off
PCI slot 2: Off
NV battery 1: Off
Boot device 1: Off
