控制器警示LED亮起、并由扩展器设置
This article may include metadata, visibility, validation state, and related support guidance.
适用场景
- FAS2720
- FAS2750
问题描述
- 控制器警示LED亮起。
- 可在以下命令输出中找到"由扩展器设置"。
示例:
FRU LEDs status
FRU LED ID 1 = BMC Locate LED
FRU LED ID 2 = BMC System LED
FRU LED ID 3 = BMC Controller Attention LED
FRU LED ID 4 = BMC Controller Active LED
FRU LED ID 5 = BMC SAS Port A Attention LED
FRU LED ID 6 = BMC SAS Port B Attention LED
FRU LED ID 7 = BMC CNA Port 1 Attention LED
FRU LED ID 8 = BMC CNA Port 2 Attention LED
FRU LED ID 9 = BMC CNA Port 3 Attention LED
FRU LED ID 10 = BMC CNA Port 4 Attention LED
FRU LED ID 11 = BMC 10G Port 1 Attention LED
FRU LED ID 12 = BMC 10G Port 2 Attention LED
FRU LED ID 13 = BMC DIMM Slot 1 Attention LED
FRU LED ID 14 = BMC DIMM Slot 2 Attention LED
FRU LED ID 15 = BMC NVMEM 1 Attention LED
FRU LED ID 16 = BMC BOOT DISK Attention LED
FRU LED ID 17 = BMC NV BATTERY Attention LED
FRU LED ID 18 = BMC Coin Cell Attention LED
FRU LED ID 1 is off
FRU LED ID 2 is on. Set by Expander
FRU LED ID 3 is off
FRU LED ID 4 is off
FRU LED ID 5 is off
FRU LED ID 6 is off
FRU LED ID 7 is off
FRU LED ID 8 is off
FRU LED ID 9 is off
FRU LED ID 10 is off
FRU LED ID 11 is off
FRU LED ID 12 is off
FRU LED ID 13 is off
FRU LED ID 14 is off
FRU LED ID 15 is off
FRU LED ID 16 is off
FRU LED ID 17 is off
FRU LED ID 18 is off
- 重新启动 BMC 无法解决此问题。
- 运行以下命令也无法解决此问题
system fru led set <ID> off命令。
BMC>priv set diag
BMC*>system fru led set <ID> off
