在FPolicy反复断开连接的情况下、CIFS客户端访问速度较慢
This article may include metadata, visibility, validation state, and related support guidance.
适用场景
- ONTAP
- CIFS
- FPolicy
问题描述
- 启用FPolicy后、CIFS客户端速度较慢
- PA会观察到高延迟
- 禁用FPolicy可解决CIFS客户端速度较慢的问题
- EMS显示以下错误:
Mon Jan 04 12:09:45 EST [example: fpolicy: fpolicy.server.connectError:error]: Node failed to establish a connection with the FPolicy server '10.1.1.101' (reason: 'Connection to FPolicy server is broken(EPIPE) received.').
Mon Jan 04 12:09:45 EST [example: fpolicy: fpolicy.server.disconnect:warning]: Connection to the Fpolicy server '10.1.1.101' is broken ( reason: 'FPolicy server is removed from external engine.' ).
Mon Jan 04 13:06:11 EST [example: fpolicy: fpolicy.server.disconnect:warning]: Connection to the Fpolicy server '10.1.1.101' is broken ( reason: 'FPolicy server is removed from external engine.' ).
Mon Jan 04 13:06:36 EST [example: fpolicy: fpolicy.server.connectError:error]: Node failed to establish a connection with the FPolicy server '10.1.1.101' (reason: 'Select Timed out.').
