跳转到主内容
拆分卷克隆期间WAFL不一致、并重新设置并行密钥
i
Knowledge Base guidance
This article may include metadata, visibility, validation state, and related support guidance.
适用场景
  • AFF
  • ONTAP <= 9.7
  • NetApp 卷加密 (NetApp Volume Encryption, NVE)
  • 已拆分卷克隆
问题描述
  • 卷克隆是从使用NVE加密的源卷创建的。
  • 克隆会拆分、这也会在ONTAP <9.7中对NVE触发并行重新设置密钥操作。
  • 运行克隆拆分+重新设置密钥的节点将出现以下情况:
    Fri Jun 30 09:22:24 UTC [node-01: wafl_exempt09: sk.panic:alert]: Panic String: Unrecoverable metadata block (file 77, block 15765045879, fbn 66948, level 0, file type 1) in volume myVolume@vserver:bef12b50-1234-dead-babe-00a098f48f12. WAFL inconsistent. Contact NetApp technical support. in SK process wafl_exempt09 on release 9.5P9 (C)
  • 由于崩溃而接管服务的HA或DR配对节点确实会触发相同的崩溃。
  • HA或DR配对节点在接管/切换中再次联机、而克隆卷处于脱机状态、标记为WAFL不一致。
  • MetroCluster切回或HA交还会被否决、类似于:
    Wed Jul 05 16:52:09 UTC [nacons-n11: vdb_apply_work22: wafl.mcc.sb.nso.veto.nvsave:error]: Switchback or negotiated switchover vetoed due to presence of NVSave files for 'Flexible Volume' (FSID 1377713130, UUID fb14c13d-dead-babe-affe-00a098f13777).
