卷加密转换失败、并显示内部错误
Knowledge Base guidance
This article may include metadata, visibility, validation state, and related support guidance.
适用场景
- ONTAP 9
- 加密
- ONTAP硬件
问题描述
- storage Failover show显示"storage Failover mailbox disk state is invalid, local node missing" and is missing"(存储故障转移邮箱磁盘状态无效、本地节点缺少配对磁盘)、并且缺少配对节点名称:
Node Name as Returned by Storage Failover Component: Node1 Partner Name: - Node NVRAM ID: 538241368 Partner NVRAM ID: 538241280 Takeover Enabled: true HA Mode: ha Takeover Possible: false Reason Takeover not Possible: Storage failover mailbox disk state is invalid Local node missing partner disks Reason Takeover not Possible (Enum value): mailbox_invalid disk_inventory_mismatch_local Interconnect Up: true Interconnect Links: RDMA Interconnect is up Interconnect Type: RoCE State Description: Connected to partner, Takeover is not possible: Storage failover mailbox disk state is invalid, Local node missing partner disks Partner State: Up
- 尝试将纯文本卷转换为NVE卷失败、并显示以下类似错误:
::> volume encryption conversion start -vserver vserver1 -volume vol0 Error: command failed: Failed to start conversion on volume "vol0" in Vserver "vserver1". Reason: Internal error. Use the "cluster show" command to verify that all nodes are healthy. Wait a few minutes and try the operation again.
