由于散热效率低下、传感器1发出温度警报
Knowledge Base guidance
This article may include metadata, visibility, validation state, and related support guidance.
适用场景
DS460磁盘架
问题描述
- 特定磁盘架会在 EMS日志 中报告来自传感器1的非严重温度过高警报。示例:
[node_name: dsa_worker1: ses.status.temperatureWarning:alert]: DS460-12 (S/N xxxxxxxxxxxxxx) shelf 3 on channel 0a temperature warning for Temperature sensor 1: non-critical status; overtemperature warning. Current temperature: 41 C (105 F). This module is on the front of the shelf on the left, on the OPS panel.
- 此警报不会显示在所有已连接的磁盘架上。
- 其他磁盘架报告的温度值接近阈值:
::> storage shelf show -shelf <stack>.<shelf_ID> -cooling
- 几分钟后、警报将变为正常状态:
[node_name: dsa_worker5: ses.status.temperatureInfo:info]: DS460-12 (S/Nxxxxxxxxxxxxxx) shelf 3 on channel 1b temperature information for Temperature sensor 1: normal status.
