系统故障LED指示灯亮起和"过流保护故障"
This article may include metadata, visibility, validation state, and related support guidance.
适用场景
- FAS2720
- FAS2750
问题描述
- 存储故障LED亮起。
- 可以在以下命令输出中找到过电压保护故障错误事件。
示例:
::> system controller service-event show
Node ID Event Location Event Description
Clusternode-01
1 10G Port 1 in Controller A Overcurrent Protection Fault
- 可以在以下命令输出中找到SP磁盘架故障RQSTD错误事件。
示例:
::> system node run -node * storage show fault -v
Enclosure Status: normal
Channel: 0a
Shelf: 0
Shelf Type: DS224-12
Product Serial Number: xxxxxxxxxxxxxxx
Module Type: IOM12E
Vendor Unique Element 88-IOM12E: (PCM)
Element Status Status Bytes Status Descriptions
1: OK 01,01,80,00 SP SHELF FAULT RQSTD
2: OK 01,01,00,00
