系统风扇转速较高、噪音较大
This article may include metadata, visibility, validation state, and related support guidance.
适用场景
- FAS系统
- AFF系统
问题描述
- 风扇噪音 很大。
system node environment sensors show表示 受影响节点的风扇速度高于其他节点的风扇速度。SP-LATEST-IPMI登录AutoSupport 还 表示 受影响节点的风扇速度高于其他节点的风扇速度。
示例:
- 受影响的节点:
FAN1:
Fan1_Status | 0x0 | discrete | Ready | na | na | na | na
Fan1_Current | 7.900 | Amps | ok | 0.000 | 0.500 | 10.000 | 12.000
Fan1_Speed1 | 8400.000 | RPM | ok | 1000.000 | 1250.000 | 9750.000 | 10000.000
Fan1_Speed2 | 8400.000 | RPM | ok | 1000.000 | 1250.000 | 9750.000 | 10000.000
Fan1_Speed3 | 8350.000 | RPM | ok | 1000.000 | 1250.000 | 9750.000 | 10000.000
Fan1_Speed4 | 8400.000 | RPM | ok | 1000.000 | 1250.000 | 9750.000 | 10000.000
Fan1_Volt1 | 11.940 | Volts | ok | 10.560 | 11.160 | 12.840 | 13.440
- 另一个节点:
FAN1:
Fan1_Current | 1.250 | Amps | ok | 0.000 | 0.500 | 10.000 | 12.000
Fan1_Speed1 | 4200.000 | RPM | ok | 1000.000 | 1250.000 | 9750.000 | 10000.000
Fan1_Speed2 | 4250.000 | RPM | ok | 1000.000 | 1250.000 | 9750.000 | 10000.000
Fan1_Speed3 | 4250.000 | RPM | ok | 1000.000 | 1250.000 | 9750.000 | 10000.000
Fan1_Speed4 | 4200.000 | RPM | ok | 1000.000 | 1250.000 | 9750.000 | 10000.000
Fan1_Volt1 | 12.000 | Volts | ok | 10.560 | 11.160 | 12.840 | 13.440
- 机箱的琥珀色指示灯可能会亮起。
