重新布线后、磁盘架显示不正确
This article may include metadata, visibility, validation state, and related support guidance.
适用场景
- FAS8700
- ONTAP 9.7P9
- DS2246磁盘架
- I/O模块(IOM)固件191
问题描述
::> node run -node <node> sysconfig -a仅显示一个路径上的磁盘架
slot 0: SAS Host Adapter 0d (Broadcom SAS3616W rev. 2, SAS, <UP>)
Firmware rev: 12.00.00.00
NVDATA rev: 12.03.01.02
Base WWN: 5:00a098:00e41eb:73
Phy State: [0] Enabled, 6.0 Gb/s
[1] Enabled, 6.0 Gb/s
[2] Enabled, 6.0 Gb/s
[3] Enabled, 6.0 Gb/s
Mini-SAS HD Vendor: OEM
Mini-SAS HD Part Number: CAB-Q10/Q10-P1M+01
Mini-SAS HD Type: Passive Copper (unequalized) 0.5m end_0
Mini-SAS HD Serial Number: M200901510002
30.0 : NETAPP X426_STBTE1T8A10 NA02 1713.5GB 520B/sect (S3Z0P62K)
33.23: NETAPP X426_HCBFE1T8A10 NA05 1713.5GB 520B/sect (08GEATPA)
Shelf 30: DS2246 Firmware rev. IOM6 A: 0191 IOM6 B: 0191
Shelf 31: DS2246 Firmware rev. IOM6 A: 0191 IOM6 B: 0200
Shelf 32: DS2246 Firmware rev. IOM6 A: 0200 IOM6 B: 0200
Shelf 33: DS2246 Firmware rev. IOM6 A: 0200 IOM6 B: 0200
slot 1: SAS Host Adapter 1c (Broadcom SAS3616W rev. 2, SAS, <UP>)
Firmware rev: 17.00.00.00
NVDATA rev: 17.01.00.11
Base WWN: 5:00605b:01098a9:88
MFG Part Number: 111-04226
Board Name: HBA 9405W-16e
Assembly: 03-50044-10006
Serial number: SPB0521908
Mini-SAS HD Part Number: 1110683242+00
Mini-SAS HD Type: Passive Copper (unequalized) 2m
Mini-SAS HD Serial Number: M200901510028
- 系统存储配置采用多路径HA
NetApp Release 9.7P9: Thu Nov 5 20:15:56 EST 2020
System ID: 0123456789 (node-01); partner ID: 0987654321 (node-02)
System Serial Number: 212121212121 (node-01)
System Rev: B2
System Storage Configuration: Multi-Path HA
- 磁盘架布线最近已更改
