跳转到主内容
使用 SP 固件 5.8 的 FAS8200/A300 上的 SPLinkDownAlert
i
Knowledge Base guidance
This article may include metadata, visibility, validation state, and related support guidance.
适用场景
  • FAS8200
  • AFF A300
  • 服务处理器( SP )固件版本: 5.8
  • SP 内部交换机版本: Version16-SB_XXII-ETHSW-RZL
问题描述
  • 系统报告 SPLinkDownAlert 消息:
示例:
Mon May 24 05:19:47 CST [Hostname: nphmd: hm.alert.raised:alert]: Alert Id = SPLinkDownAlert, Alerting Resource = SP Config raised by monitor controller
  • E0M 链路已启动, SP 处于联机状态,而 sysconfig -a 中没有 IP 地址:
示例:
Service Processor           Status: Online
 Firmware Version:   5.8
  Mgmt MAC Address:
  Ethernet Link:     down, full duplex, auto-neg complete
  Using DHCP:         no
 IPv4 configuration:
  IP Address:         unknown
  Netmask:            unknown
  Gateway:            unknown
 IPv6 configuration:         Disabled
slot 0: Gigabit Ethernet I210
  e0M MAC Address:    (auto-1000t-fd-up)
  Device Type:        1533
  Firmware Version:   3.25-5.5 0x80000674
  • SP 内部交换机版本为 16-SB_XXII-ETHSW-RZL 。
"sp-latest-configuration" 中的示例:
Check revision of programmable devices with revision of images bundled in SP (/usr/local/bin/check_fw_revision.sh)
Versions that do not match will be printed.
Ethernet switch version
Version16 SB_XXII ETHSW RZL
  • 这篇文章对您有帮助吗?
