跳转到主内容
无法更改电源固件
i
Knowledge Base guidance
This article may include metadata, visibility, validation state, and related support guidance.
适用场景
  • AFF 系列
  • FAS 系列
  • 已更换电源设备( PSU )
问题描述
storage shelf show 在更换 PSU 后,显示的固件版本与先前的版本不同。
更换前:
Power Supply Units:
                           Crest  Power   Reset   PSU        Operational
 ID
Type Part#     Serial#      Power Rating   Factor Drawn   Capable Enabled Firmware Status       PSU Location
  1 7D   114-00148+E0 PSQ09418470XXXX 913       0    0     false   true   0111    normal       rear of the shelf at thebottom left
  2 7D   114-00148+E0 PSQ09418470XXXX 913       0    0     false   true  0111   off        rear of the shelf at the bottom right
更换后:
Power Supply Units:
                           Crest  Power   Reset
PSU        Operational
 ID Type Part#     Serial#      Power Rating   Factor Drawn   Capable Enabled Firmware Status     PSU Location
  1 7D   114-00148+E0 PSQ09418470XXXX 913       0    0     false   true   0111    normal   rear of the shelf at the bottom left
  2 98   114-00148+F1 PSQ09418470XXXX 913       0    0     false   true  0110   normal   rear of the shelf at the bottom right
  • 这篇文章对您有帮助吗?
