跳转到主内容
DS2246 和 FAS2240 上的操作面板 / 显示面板失败
i
Knowledge Base guidance
This article may include metadata, visibility, validation state, and related support guidance.
适用于
Data ONTAP 7-模式
问题
  • 控制器上的琥珀色指示灯亮起,并显示相应的 EMS 消息
    • DS2246 (S/N xxxxxxxxxx) shelf 0 on channel 0a display warning for Display 1: not installed or failed; display panel failed. This module is on the front side of the shelf, at the left. Fault reported on disk storage shelf attached to channel 0a. Please check fans, power supplies, disks, and temperature sensors.
