无法访问节点管理和SP IP地址
This article may include metadata, visibility, validation state, and related support guidance.
适用场景
- FAS/AFA系统
- ONTAP 9
- 服务处理器 (SP)
问题描述
- 无法通过Ping/SSH访问节点管理IP和SP IP。
- e0M 端口将从节点端显示:
Cluster::> system node run -node <node> -command sysconfig -a
slot 0: Gigabit Ethernet I210
e0M MAC Address: d0:39:ea:a0:f9:02 (auto-1000t-fd-up)
- 在 事件日志中发现e0M链接发生轻拍:
[Node-01: mgmt_port_link_status_poll: netif.linkDown:info]: Ethernet Wrench Port: Link down, check cable.
[Node-01: vifmgr: vifmgr.portdown:notice]: A link down event was received on node Node-01, port e0M.
[Node-01: vifmgr: vifmgr.lifmoved.linkdown:notice]: LIF Node-01_mgmt1 (on virtual server 429XXXXX95), IP address 10.XXX.XX.XXX, is being moved to node Node-01, port e0M.
[Node-01: vifmgr: vifmgr.lifBeingRemoved:notice]: LIF Node-01_mgmt1 (on virtual server 429XXXXX95), IP address 10.XXX.XX.XXX, is being removed from node Node-01, port e0M.
[Node-01: mgmt_port_link_status_poll: netif.linkUp:info]: Ethernet Wrench Port: Link up.
[Node-01: vifmgr: vifmgr.portup:notice]: A link up event was received on node Node-01, port e0M.
- e0M端口上有一个绿色指示灯。但是、 连接到e0M的交换机端口上没有LED。
