跳转到主内容
运行 boot_ontap 时,节点将启动至维护模式
i
Knowledge Base guidance
This article may include metadata, visibility, validation state, and related support guidance.
适用场景
  • ONTAP 9
  • Data ONTAP 8
问题描述
  • boot_ontap 从加载程序提示符运行时、节点始终会启动到维护模式。
  • 此时将显示以下消息:
NOTE: You have chosen to boot the diagnostics kernel.
The system has booted in maintenance mode allowing the
Use the 'sldiag' command in order to run diagnostics on the system.
