FAS8300/FAS8700 系统上的 NVRAM 电池电量过低警报
Knowledge Base guidance
This article may include metadata, visibility, validation state, and related support guidance.
适用于
- AFF A400
- FAS8300
- FAS8700
- ONTAP9.15.1P7
- BMC 13.11P1
问题描述
- EMS 事件报告多个警报,表明 NVRAM 电池电量过低,可能会导致系统在 24 小时内停止运行。
ALERT monitor.shutdown.nvramLowBattery.pending: NVRAM battery is dangerously low. Halting system in 24 hours. Replace the battery immediately!
ALERT callhome.battery.low: Call home for BATTERY_LOW.
EMERGENCY monitor.nvramLowBattery: NVRAM battery is dangerously low.
ERROR nvmem.battery.capLowWarn: The NVMEM battery capacity is below normal (4 cycles).ALERT monitor.shutdown.nvramLowBattery.pending: NVRAM battery is dangerously low. Halting system in 23 hours. Replace the battery immediately!- NVMEM 电池容量低于正常值(4 个周期)。
::*> system node environment sensors show -name "Bat Curr"|"Bat Dstg Cycles"
Node Sensor State Value/Units Crit-Low Warn-Low Warn-Hi Crit-Hi
Node01
Bat Curr normal
0 mA - - 1225 1475
Bat Dstg Cycles warn-low
4 cycles 2 5 - -
Node02
Bat Curr normal
0 mA - - 1225 1475
Bat Dstg Cycles normal
14 cycles 2 5 - -- SP-LATEST-STATISTICS 显示了相对电荷的下降
=-=-=-=-=-= Tue Jul 08, 2025 00:27:02 +0530 SP-LATEST-STATISTICS 1 line
RelativeCharge : 21 %
=-=-=-=-=-= Tue Jul 08, 2025 13:13:18 +0530 SP-LATEST-STATISTICS 1 line
=-=-=-=-=-= Wed Jul 09, 2025 00:17:03 +0530 SP-LATEST-STATISTICS 1 line
RelativeCharge : 19 %
=-=-=-=-=-= Wed Jul 09, 2025 13:13:18 +0530 SP-LATEST-STATISTICS 1 line
=-=-=-=-=-= Thu Jul 10, 2025 00:37:04 +0530 SP-LATEST-STATISTICS 1 line
RelativeCharge : 18 %
=-=-=-=-=-= Thu Jul 10, 2025 13:13:18 +0530 SP-LATEST-STATISTICS 1 line
