在上的活动学习周期内发出NVMEM电池警报
This article may include metadata, visibility, validation state, and related support guidance.
适用场景
- FAS2620
- FAS2750
- ONTAP 9
问题描述
- EMS日志中node01上的NVRAM电池电量低到危险程度。
[node01: statd: monitor.nvramLowBattery:EMERGENCY]: NVRAM battery is dangerously low.
[node01: statd: monitor.nvramLowBattery.notice:notice]: If the NVRAM battery is dangerously low, the system shuts down automatically every 24 hours to encourage you to replace it. If you reboot the system it will run for another 24 hours before shutting down.
[node01: statd: callhome.battery.low:alert]: Call home for BATTERY_LOW.
[node01: statd: monitor.shutdown.nvramLowBattery.pending:alert]: NVRAM battery is dangerously low. Halting system in 24 hours. Replace the battery immediately!
- 两小时后、SNMP陷阱"dhmNoticeDegradedIO"将发送到客户的监控服务器。
Unsupported Alert,2022/11/02 03:00:12,xxxxxxxx,node01(primary external storage)_tenant 00006100,[failure][node01]dhmNoticeDegradedIO,NNMI_INCIDENT,Run
- 此时将从SP日志执行NVRAM电池学习周期。
SP events all
[IPMI.notice]: 7e02 | 02 | EVT: 0301ffff | Bat_Lrn_Active | Assertion Event, "State Asserted"
[IPMI.notice]: 7f02 | 02 | EVT: 01500005 | Bat_Dstg_Cycles | Assertion Event, "Lower Non-critical going low "
[IPMI.notice]: 8002 | 02 | EVT: 01520002 | Bat_Dstg_Cycles | Assertion Event, "Lower Critical going low "
[IPMI.notice]: 8102 | 02 | EVT: 81520402 | Bat_Dstg_Cycles | Deassertion Event, "Lower Critical going low "
[IPMI.notice]: 8202 | 02 | EVT: 81500d05 | Bat_Dstg_Cycles | Deassertion Event, "Lower Non-critical going low "
[IPMI.notice]: 8302 | 02 | EVT: 0301ffff | Attn_Sensor1 | Assertion Event, "State Asserted"
[IPMI.notice]: 8402 | 02 | EVT: 0300ffff | Attn_Sensor1 | Assertion Event, "State Deasserted"
[IPMI.notice]: 8502 | 02 | EVT: 0300ffff | Bat_Lrn_Active | Assertion Event, "State Deasserted"
SP LATEST IPMI
LrnCycleStartDate : 22-11-01-12:00
LrnCycleStartFCC : 0x052f
LrnCycleEndFCC : 0x0347
LrnCycleEndDate : 22-11-01-18:30
