跳转到主内容
多个IO风扇出现故障并关闭系统
i
Knowledge Base guidance
This article may include metadata, visibility, validation state, and related support guidance.
适用场景
  • FAS6280
  • FAS8080
  • 服务处理器 (SP)
问题描述
  • 在以下命令输出中可以找到"Multiple IO fans failed (多个IO风扇出现故障)"错误事件。
示例:
SP*> system log
Fri May 29 13:19:25 CST [cluster-B:monitor.power.unreadable:info]: A power sensor IO AUX 3.3V in the controller module is not readable.
Fri May 29 13:19:25 CST [cluster-B:monitor.power.unreadable:info]: A power sensor IO AUX 1.2V in the controller module is not readable.
Fri May 29 13:19:25 CST [cluster-B:monitor.power.unreadable:info]: A power sensor IO SWC 2.5V in the controller module is not readable.
Fri May 29 13:19:25 CST [cluster-B:monitor.power.unreadable:info]: A power sensor IO SWC 1.5V in the controller module is not readable.
Fri May 29 13:19:25 CST [cluster-B:monitor.power.unreadable:info]: A power sensor IO STBY 12V in the controller module is not readable.
Fri May 29 13:19:25 CST [cluster-B:monitor.power.unreadable:info]: A power sensor IO STBY 5V in the controller module is not readable.
Fri May 29 13:19:25 CST [cluster-B:monitor.power.unreadable:info]: A power sensor IO STBY 3.3V in the controller module is not readable.
Fri May 29 13:19:25 CST [cluster-B:monitor.power.unreadable:info]: A power sensor IO 12V in the controller module is not readable.
Fri May 29 13:19:25 CST [cluster-B:monitor.power.unreadable:info]: A power sensor IO 3.3V in the controller module is not readable.
Fri May 29 13:19:25 CST [cluster-B:monitor.power.unreadable:info]: A power sensor IO STBY MP 5V in the controller module is not readable.
Fri May 29 13:19:25 CST [cluster-B:monitor.power.unreadable:info]: A power sensor IO MP 12V in the controller module is not readable.
Fri May 29 13:19:25 CST [cluster-B:monitor.power.unreadable:info]: A power sensor IO PCI Swt R 1V in the controller module is not readable.
Fri May 29 13:19:25 CST [cluster-B:monitor.power.unreadable:info]: A power sensor IO PCI Swt L 1V in the controller module is not readable.
Fri May 29 13:22:56 CST [cluster-B:callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: IOFan3 F2
Fri May 29 13:22:56 CST [cluster-B:monitor.chassisFan.stop:ALERT]: Chassis fan contains at least one stopped fan: IOFan3 F2 (failed)
Fri May 29 13:22:56 CST [cluster-B:callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: IOFan3 F1
Fri May 29 13:22:56 CST [cluster-B:monitor.chassisFan.stop:ALERT]: Chassis fan contains at least one stopped fan: IOFan3 F1 (failed)
Fri May 29 13:22:56 CST [cluster-B:callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: IOFan2 F2
Fri May 29 13:22:56 CST [cluster-B:monitor.chassisFan.stop:ALERT]: Chassis fan contains at least one stopped fan: IOFan2 F2 (failed)
Fri May 29 13:22:56 CST [cluster-B:callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: IOFan2 F1
Fri May 29 13:22:56 CST [cluster-B:monitor.chassisFan.stop:ALERT]: Chassis fan contains at least one stopped fan: IOFan2 F1 (failed)
Fri May 29 13:22:56 CST [cluster-B:callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: IOFan1 F2
Fri May 29 13:22:56 CST [cluster-B:monitor.chassisFan.stop:ALERT]: Chassis fan contains at least one stopped fan: IOFan1 F2 (failed)
Fri May 29 13:22:56 CST [cluster-B:callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: IOFan1 F1
Fri May 29 13:22:56 CST [cluster-B:monitor.chassisFan.stop:ALERT]: Chassis fan contains at least one stopped fan: IOFan1 F1 (failed)
Fri May 29 13:22:56 CST [cluster-B:monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Multiple chassis fans have failed.
Fri May 29 13:23:00 CST [cluster-B:monitor.globalStatus.critical:CRITICAL]: Multiple fans failed: IOFan1 F1, IOFan1 F2, IOFan2 F1, IOFan2 F2, IOFan3 F1, IOFan3 F2.
Fri May 29 13:23:06 CST [cluster-B:monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Multiple IO fans failed)
  • 无法读取IOXM Nuvoton错误事件可在以下命令输出中找到。
示例:
cat /var/log/messages
May 29 06:18:32 (none) : [438 WARNING][Absolut.c:5173]**** Failed to read IOXM Nuvoton config: Bank 2 Reg 0x2 Data 0x0 Error -1
May 29 06:18:32 (none) : [438 WARNING][libi2c.c:806]Error: i2c_multimsg: intended=4pkts, actual=-1pkts, w:b=4:sa=0xe0:n=1, w:b=4:sa=0x58:n=2, w:b=4:sa=0x58:n=1, r:b=4:sa=0x58:n=1,
May 29 06:18:32 (none) last message repeated 2 times
May 29 06:18:32 (none) : [438 WARNING][Absolut.c:5173]**** Failed to read IOXM Nuvoton config: Bank 2 Reg 0x3 Data 0x0 Error -1
May 29 06:18:32 (none) : [438 WARNING][Absolut.c:5173]**** Failed to read IOXM Nuvoton config: Bank 2 Reg 0x4 Data 0x0 Error -1
May 29 06:18:32 (none) : [438 WARNING][Absolut.c:5173]**** Failed to read IOXM Nuvoton config: Bank 2 Reg 0x5 Data 0x0 Error -1
