AFF A250/FAS500f Low BAT_dstg_Cycls发生原因 电池(容量低)错误
This article may include metadata, visibility, validation state, and related support guidance.
适用场景
- AFF A250
- FAS500f
- NVMEM电池固件C0或更低版本
BMC node-name>system battery show
DeviceChemistry : LION
ChemistryID : 0x1968
DeviceName : bq40z50-R2
ManufacturerName : Inv27100073+C0
FW version : C0
问题描述
- 事件
BATTERY (capacity low)
1/1/2022 00:00:00 node-name ALERT callhome.battery.low: Call home for BATTERY_LOW.
1/1/2022 00:00:00 node-name EMERGENCY monitor.nvramLowBattery: NVRAM battery is dangerously low.
1/1/2022 00:00:00 node-name ALERT callhome.battery.warning: Call home for BATTERY (capacity low) WARNING.
- 报告 错误和更正(正常)的EMS消息:
[node-name: env_mgr: nvmem.battery.capLowWarn:error]: The NVMEM battery capacity is below normal (5 cycles).
[node-name: env_mgr: callhome.battery.notice:notice]: Call home for BATTERY (capacity low) NOTICE.
[node-name: env_mgr: nvmem.battery.capNormal:notice]: The NVMEM battery capacity is normal.
- 电池电量低的BMC事件:
123 | 06/16/2022 | 16:56:09 | Battery #0x49 | Lower Non-critical going low
system sensors show报告Bat_Dstg_Cycles小于或等于lnc
=================== sensor ==========================
Sensor name | reading | unit | status| lnr | lcr | lnc | unc | ucr | unr
Bat_Temp | 34.500 | degrees C | ok | 0.000 | 0.000 | 5.000 | 60.000 | 75.000 | 127.500
Bat_Volt | 8.100 | Volts | ok | 0.000 | 5.500 | 5.600 | 8.500 | 8.600 | 12.750
Bat_Curr | 0.000 | Amps | ok | na | na | na | 1.200 | 1.520 | 2.540
Bat_Rem_Cap | 9.840 | Watts * hour | ok | na | na | na | na | na | na
Bat_Full_Cap | 10.800 | Watts * hour | ok | na | na | na | na | na | na
Bat_Charge_Curr | 0.000 | Amps | ok | na | na | na | 2.200 | 2.300 | 5.100
Bat_Charge_Volt | 8.200 | Volts | ok | na | na | na | 8.900 | 9.000 | 12.750
Bat_Design_Cap | 18.400 | Watts * hour | ok | na | na | na | na | na | na
Bat_Initial_Fcc | 20.400 | Watts * hour | ok | na | na | na | na | na | na
Bat_Dstg_Cycles | 4.000 | cycles | nc | na | 2.000 | 5.000 | na | na | na
Bat_Cycle_Cnt | 0.000 | cycles | ok | na | na | na | na | na | na
Bat_Power_Fault | 0x0 | discrete | 0x0180| na | na | na | na | na | na
Bat_Dsg_FET_Flt | 0x0 | discrete | 0x0280| na | na | na | na | na | na
Bat_Chg_FET_Flt | 0x0 | discrete | 0x0280| na | na | na | na | na | na
Bat_Pack_Invalid | 0x0 | discrete | 0x0180| na | na | na | na | na | na
Bat_Lrn_Active | 0x0 | discrete | 0x0180| na | na | na | na | na | na
- 已排除误报NVMEM电池警报选项、如 AF-A250报告电池(容量低)警报 和错误 1447722中所述
- 监控
EMS.logThe NVMEM battery capacity is below normal 在消息末尾、我们看到(# cycles)- 周期数降至5以下
