如何读取 AFF/FAS 系统上的 IFstat 计数器
This article may include metadata, visibility, validation state, and related support guidance.
适用场景
- ONTAP 9
- 集群模式 Data ONTAP 8
- Data ONTAP 7-模式
问题描述
Data ONTAP 7-模式
node_name> ifstat [ -z ] -a | <interface_name>
集群模式 Data ONTAP 8 和 ONTAP 9
此命令从每个节点的 Nodeshell 执行
cluster::> system node run -node <node_name> -command ifstat [ -z ] -a | <interface_name>
输出示例
cluster::> system node run -node node_example> -command ifstat e0a
-- interface e0a (6 days, 19 hours, 46 minutes, 1 second) --
RECEIVE
Frames/second: 6 | Bytes/second: 551 | Errors/minute: 0
Discards/minute: 0 | Total frames: 249k | Total bytes: 19489k
Total errors: 0 | Total discards: 0 | Multi/broadcast: 235k
No buffers: 0 | Non-primary u/c: 0 | L2 terminate: 0
Tag drop: 0 | Vlan tag drop: 0 | Vlan untag drop: 0
Vlan forwards: 0 | Vlan broadcasts: 0 | Vlan unicasts: 0
CRC errors: 0 | Alignment errors: 0 | Runt frames: 0
Long frames: 0 | Fragment: 0 | Jabber: 0
Xon: 0 | Xoff: 0 | Ring full: 0
Jumbo: 0 | Jumbo error: 0 | Index error: 0
Force wakeup: 0
TRANSMIT
Frames/second: 4 | Bytes/second: 659 | Errors/minute: 0
Discards/minute: 0 | Total frames: 26386 | Total bytes: 2443k
Total errors: 0 | Total discards: 0 | Multi/broadcast: 11256
Queue overflows: 0 | No buffers: 0 | Single collision: 0
Multi collisions: 0 | Late collisions: 0 | Max collisions: 0
Deferred: 0 | Xon: 0 | Xoff: 0
MAC Internal: 0 | Jumbo: 0
LINK_INFO
Current state: up | Up to downs: 0 | Speed: 1000m
Duplex: full | Flowcontrol: full
注:
-z参数将清除统计信息-a参数用于显示所有网络接口的统计信息、包括虚拟主机和环回地址。或者、您也可以省略-a此参数并指定网络接口的名称。
