更换主板后未检测到HBA卡X2071A
Knowledge Base guidance
This article may include metadata, visibility, validation state, and related support guidance.
适用场景
- FAS/AFA系统。
- ONTAP 9
- HBA卡 X2071A
问题描述
- 替换MB后、 由于配对节点上缺少文件系统磁盘、无法交还。
[Node-1: svc_queue_thread: cf.disk.invent.mismatchalt:debug]: Status of some of the disks has changed or the node (Node-2) is missing 147 disks (detailed logs have been throttled).- 进一步检查 维护模式下的sasadmin expander_map输出、发现 新更换的主板上缺少插槽X连接。
- 重新拔插卡也导致相同的错误。
