跳转到主内容
故障 LED 亮起,没有实际问题
i
Knowledge Base guidance
This article may include metadata, visibility, validation state, and related support guidance.
适用场景
纯 AFF/FAS
问题描述
  • 警示 LED 亮起,即使没有实际问题。
  • 在某些情况下,由于组件出现故障, LED 亮起,在修复后仍保持亮起状态。
::> system health alert show
This table is currently empty.
::> system health status show
Status
ok
::> system health subsystem show
Subsystem      Health
SAS-connect     ok
Environment     ok
Memory       ok
  • fru LED status 命令指示 LED 状态为 on 。例如:
    • ONTAP OS 7- 模式
node*> fru_led status
Controller slot A: On (lit by Data ONTAP)
DIMM slot 1:     Off
DIMM slot 2:     Off
DIMM slot 3:     Off
DIMM-NV slot 1:   Off
PCI slot 1:     On
PCI slot 2:     Off
  • ONTAP OS 集群模式:
::*> system controller fru led show
Node          FRU Type   Bay Slot State   Lit By
node_name
            controller   A 1   on    SP
            ioxm      B 1   off    -
            pci       - 1   off    -
