风扇"x"正在运行、低于正常RPM阈值
This article may include metadata, visibility, validation state, and related support guidance.
适用场景
- DS460C磁盘架
- 风扇
问题描述
- 风扇在低于正常转速阈值的情况下运行
node01::> storage shelf show -errors
Shelf Name: xx.xx
Shelf UID: xx:xx:xx:xx:xx:xx:xx:xx
Serial Number: xxxxxxxxxxxxxx
Error Type Description
Fan Fan "x" is running below normal RPM threshold. Fan is located in the rear of the shelf to the left.
STORAGE-FAULT还显示风扇严重
Fans:
Element Status Status Bytes Status Descriptions
1: CRITICAL 02,05,1F,A7
2: OK 01,04,4A,A5
3: OK 01,03,57,A3
4: OK 01,02,D0,A2
5: OK 01,03,4B,A3
6: OK 01,02,C1,A2
7: OK 01,03,0F,A3
8: OK 01,02,A0,A2
ENVIRONMENT显示无异常转速
Shelf: x
Cooling Unit installed element list: 1, 2, 3, 4, 5, 6, 7, 8; with error: 1
Cooling Units by element:
[1] 12990 RPM
[2] 10980 RPM
[3] 10740 RPM
[4] 11280 RPM
[5] 13020 RPM
[6] 11160 RPM
[7] 10680 RPM
[8] 11280 RPM
