FAS2554 警示 LED 亮起
Knowledge Base guidance
This article may include metadata, visibility, validation state, and related support guidance.
适用场景
- FAS2554
- 7-模式 Data ONTAP
- 服务处理器( SP )固件 2.2.5P2
问题描述
- 控制器警示 LED 亮起
- ONTAP 命令
storage show fault -v会报告状态正常,但所有 PSU 均具有DC UNDER VOLTAGE
node_name> storage show fault -v
Enclosure Status: normal
Channel: 0a
Shelf: 0
Shelf Type: DS4246
Product Serial Number: serial_number
Module Type: IOM6E
Power Supplies:
Element Status Status Bytes Status Descriptions
1: OK 01,00,04,A0 DC UNDER VOLTAGE, RQSTED ON
2: OK 01,00,04,A0 DC UNDER VOLTAGE, RQSTED ON
3: OK 01,00,04,A0 DC UNDER VOLTAGE, RQSTED ON
4: OK 01,00,04,A0 DC UNDER VOLTAGE, RQSTED ON
