环境原因关闭(电池电流临界)
This article may include metadata, visibility, validation state, and related support guidance.
适用于
- FAS8300
- ONTAP 9
- BMC 11.8
问题
FAS8300 节点频繁关机。系统控制台日志显示以下错误:
Jun 12 07:51:01 [N2:nvmem.battery.currentHigh:EMERGENCY]: The NVMEM battery current is critically high (2450mA). To prevent data loss, the system will shutdown in 5 minutes.
Jun 12 13:01:11 [N2:nvmem.battery.currentHigh:EMERGENCY]: The NVMEM battery current is critically high (2225mA). To prevent data loss, the system will shutdown in 5 minutes.
Jun 25 09:50:39 [N2:nvmem.battery.currentHigh:EMERGENCY]: The NVMEM battery current is critically high (1725mA). To prevent data loss, the system will shutdown in 5 minutes.
Jun 25 09:55:38 [N2:monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Battery current critical)
