跳转到主内容
在 PCI 总线上未检测到设备( " 以太网:扳手端口 " )
i
Knowledge Base guidance
This article may include metadata, visibility, validation state, and related support guidance.
适用于
  • AFF-A200
  • FAS2650
  • ONTAP
问题
  • 在启动 ONTAP 期间,您可能会看到与以下类似的错误,并且系统将无法开机自检。
  • 在启动期间,节点会报告以下错误并暂停到 LOADER 提示符:
Device ("Ethernet:Wrench Port" ) not detected on PCI BUS.
Device could be purposely held in reset or has developed a physical defect or has a corrupt firmware.
Halting the system because the device is critical for normal operations. Bootarg no-onboard-pcidev-check? can skip this check.
Halting...
BIOS Version: 11.0.2
Portions Copyright (C) 2014-2016 NetApp, Inc. All Rights Reserved.
Initializing System Memory ...
Loading Device Drivers ...
Configuring Devices ...
CPU = 1 Processor(s) Detected.
  Intel(R) Xeon(R) CPU D-1528 @ 1.90GHz (CPU 0)
  CPUID: 0x00050663. Cores per Processor = 6
32768 MB System RAM Installed.
SATA (AHCI) Device: SV9MST6D120GLM41NP
Boot Loader version 6.0
Copyright (C) 2000-2003 Broadcom Corporation.
Portions Copyright (C) 2002-2016 NetApp, Inc. All Rights Reserved.
BIOS POST Failure(s) detected: PCIe device missing error detected. Abort AUTOBOOT
