跳转到主内容
HA 对无法读取 AF-A800 上的机箱温度传感器
i
Knowledge Base guidance
This article may include metadata, visibility, validation state, and related support guidance.
适用场景
  • AFF-A800
问题描述
  • 在提示在环境中关闭 HA 对之前, AF-A800 会显示机箱温度过高
  • 可能会看到以下传感器故障读数:
Wed Jan 20 23:22:51 -0300 [node: env_mgr: monitor.temp.unreadable:error]: The controller temperature (RiserM RTemp1) is not readable.
Wed Jan 20 23:22:51 -0300 [node: env_mgr: monitor.temp.unreadable:error]: The controller temperature (RiserM LTemp2) is not readable.
Wed Jan 20 23:22:51 -0300 [node: env_mgr: monitor.temp.unreadable:error]: The controller temperature (RiserM RTemp2) is not readable.
Wed Jan 20 23:22:51 -0300 [node: env_mgr: monitor.temp.unreadable:error]: The controller temperature (RiserM LTemp3) is not readable.
Wed Jan 20 23:22:52 -0300 [node: env_mgr: monitor.temp.unreadable:error]: The controller temperature (RiserM RTemp3) is not readable.
Wed Jan 20 23:22:52 -0300 [node: env_mgr: monitor.temp.unreadable:error]: The controller temperature (RiserM LTemp4) is not readable.
Wed Jan 20 23:22:52 -0300 [node: env_mgr: monitor.temp.unreadable:error]: The controller temperature (RiserM RTemp4) is not readable.
Wed Jan 20 23:22:52 -0300 [node: env_mgr: monitor.temp.unreadable:error]: The controller temperature (RiserR LTemp1) is not readable.
Wed Jan 20 23:22:52 -0300 [node: env_mgr: monitor.temp.unreadable:error]: The controller temperature (LED Board Temp2) is not readable.
  • 事件日志中显示以下事件。
[NACA800-01: monitor: monitor.globalStatus.critical:EMERGENCY]: Chassis temperature is too high..
[NACA800-01: env_mgr: callhome.chassis.overtemp:EMERGENCY]: Call home for CHASSIS OVER TEMPERATURE SHUTDOWN
[NACA800-01: env_mgr: callhome.chassis.hitemp:error]: Call home for CHASSIS OVER TEMPERATURE
