机箱电源已降级,并显示 "PSU 温度警告下限 "
Knowledge Base guidance
This article may include metadata, visibility, validation state, and related support guidance.
适用于
- AFF
- FAS
问题
- 机箱电源降级 AutoSupport 仍会发出警报,并在降级 / 正常之间切换。
HA Group Notification (CHASSIS POWER DEGRADED: Power Supply Status Critical: PSU1.) ERROR
HA Group Notification (CHASSIS POWER SUPPLY DEGRADED: PS 1) ERROR
HA Group Notification (CHASSIS POWER SUPPLY OK: PS 1) NOTICE
HA Group Notification (CHASSIS POWER DEGRADED: Power Supply Status Critical: PSU2.) ERROR
HA Group Notification (CHASSIS POWER SUPPLY DEGRADED: PS 2) ERROR
HA Group Notification (CHASSIS POWER SUPPLY OK: PS 2) NOTICE
- EMS 错误包括温度警报:
[?] Sat Aug 08 14:15:01 EDT [node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Temperature is Warning Low (4 C)[?] Sat Aug 08 14:15:03 EDT [node-01: power_low_monitor: monitor.chassisPower.degraded:alert]: Chassis power is degraded: Power Supply Status Critical: PSU1.[?] Sat Aug 08 14:17:44 EDT [node-01: env_mgr: monitor.chassisPowerSupply.ok:info]: Chassis power supply 1 is OK.[?] Sat Aug 08 14:17:53 EDT [node-01: power_low_monitor: monitor.chassisPowerSupplies.ok:info]: Chassis power supplies OK.- 其他机箱 PSU ,集群中的其他节点和磁盘架上的温度均较低,并接近警告阈值下限。
