跳转到主内容
检测到CN1610风扇警告低速度
i
Knowledge Base guidance
This article may include metadata, visibility, validation state, and related support guidance.
适用场景
CN1610
问题描述
CN1610 show tech-support 日志显示"Warning Low speed detected" errors。
show tech-support:
 CN1610-1 BSP[envMonTask]: cpu_boxs.c(2128) 159639 %% Setting normal fan speed !
 CN1610-1 BSP[envMonTask]: cpu_boxs.c(1751) 159638 %% Requesting normal fan speed !
 CN1610-1 BSP[envMonTask]: cpu_boxs.c(1743) 159636 %% Requesting maximum fan speed !
 CN1610-1 BSP[envMonTask]: cpu_boxs.c(1646) 159635 %% Fan #1: Warning Low speed detected: 3000 rpm !
 CN1610-1 BSP[envMonTask]: cpu_boxs.c(2128) 159628 %% Setting normal fan speed !
 CN1610-1 BSP[envMonTask]: cpu_boxs.c(1751) 159627 %% Requesting normal fan speed !
 CN1610-1 TRAPMGR[boxs Req]: traputil.c(777) 159626 %% Fan state change alarm: Unit: 1  Fan ID: 1  Event: 3 -Operational
 CN1610-1 BOXSERV[boxs Req]: boxs.c(1095) 159625 %% Unit 1 fan 1  OPERATIONAL event (3)occurred.
 CN1610-1 TRAPMGR[boxs Req]: traputil.c(777) 159624 %% Fan state change alarm: Unit: 1  Fan ID: 1 Event: 4 - Failure
 CN1610-1 BOXSERV[boxs Req]: boxs.c(1095) 159623 %% Unit 1 fan 1  FAILURE event (4) occurred.
 CN1610-1 BSP[envMonTask]: cpu_boxs.c(1743) 159621 %% Requesting maximum fan speed !
 CN1610-1 BSP[envMonTask]: cpu_boxs.c(1716) 159620 %% Detected 3 fans operational !
 CN1610-1 BSP[envMonTask]: cpu_boxs.c(1622) 159619 %% Fan #1: Critical Low speed detected: 2640 rpm
Fans:
Unit Fan Description   Type    Speed      Duty level   State
1   1   Fan-1      Removable 6180      50%       Operational
1   2   Fan-2      Removable 6240      50%       Operational
1   3   Fan-3      Removable 6420      50%       Operational
1   4   Fan-4      Removable 6300      50%       Operational
Power Modules:
Unit    Power supply   Description     Type      State
1     1        Internal AC-1    Removable    Operational
1     2        Internal AC-2    Removable    Operational
