跳转到主内容
1个节点报告AFF A300机箱风扇FRU故障
i
Knowledge Base guidance
This article may include metadata, visibility, validation state, and related support guidance.
适用场景
  • FAS8200
  • AFF A300
  • ONTAP 9
问题描述
  • 其中一个节点报告 机箱风扇FRU 出现故障
callhome.c.fan.fru.fault: Call home for CHASSIS FAN FRU FAILED: SysFan1 F1
callhome.c.fan.fru.fault: Call home for CHASSIS FAN FRU FAILED: SysFan1 F2
  • 事件日志中报告了多个错误和警报
Cluster::> event log show
Time                Node             Severity      Event
2/24/2025 02:19:58  Node B      ERROR         monitor.chassisFan.stop: Chassis fan contains at least one stopped fan: SysFan1 F2 (failed)
2/24/2025 02:19:58  Node B      ERROR         monitor.chassisFan.stop: Chassis fan contains at least one stopped fan: SysFan1 F1 (failed)
2/24/2025 02:00:00  Node B      ALERT         monitor.fan.failed: Multiple fans has failed: Sysfan1 F1, Sysfan1 F2.
2/24/2025 01:25:03  Node B      ALERT         callhome.hm.alert.critical: Call home for Health Monitor process cphm: CriticalFruMultiFaultAlert.
2/24/2025 01:24:47  Node B      ALERT         hm.alert.raised: Alert Id =CriticalFruMultiFaultAlert, Alerting Resource = xxxx raised by monitor chassis
2/24/2025 01:20:00  Node B      EMERGENCY     monitor.globalStatus.critical: Multiple fans has failed: Sysfan1 F1, Sysfan1 F2.
  • system node environment sensors show 的输出显示FAN1存在故障
Node Sensor                 State Value/Units Crit-Low Warn-Low Warn-Hi Crit-Hi
Node B
     Fan3                  normal
                                         GOOD
     Fan2                  normal
                                         GOOD
     Fan1                  fault
                                         MULTIFAULT
  • 节点A在sysconfig -M 中正确报告了风扇FRU信息 、但节点B显示错误
Node A
!FAN1!042142036602!!441-00025!A1!
!FAN2!021917019266!!441-00025!A1!
!FAN3!021917019271!!441-00025!A1!
Node B
!FAN1: Error reading FRU EEPROM
  • 已更换风扇FRU、但问题描述未解决
