跳转到主内容
学习周期之外触发电池温度低警报
i
Knowledge Base guidance
This article may include metadata, visibility, validation state, and related support guidance.
适用场景
  • FAS2650
  • ONTAP 9.7P22
问题描述
  • 由于电池温度过低,触发了以下 ASUP (AutoSupport) 警报:
HA Group Notification from NAP-CL7-02 (BATTERY (temperature low)) ALERT
  • system sensors 显示电池温度为critlow(极低),一些传感器显示not_available温度为-17°C。
Bat Volt                 normal          8100 mV     5500 mV 5600 mV     8500 mV     8600 mV
Bat Pct Capacity         normal            64 %        39 %        44 %        --          --
Bat Curr                not_available     -- mA       --          --        1200 mA     1520 mA
Bat Rem Cap              normal            768 mA*hr    --          --          --          --
Bat Full Cap             normal          1024 mA*hr    --          --          --          --
Bat Charge Curr         not_available     -- mA       --          --        2200 mA    2300 mA
Bat Charging State      failed             --
Bat Charge Volt          normal          8200 mV       --          --        8900 mV     9000 mV
Bat Initial FCC          normal          1600 mA*hr    --          --          --          --
Bat Dstg Cycles          normal            13 cycles    2 cycles    5 cycles   --          --
Bat Power Fault          GOOD
Bat Dcharge FET          ON
Bat Charge FET           ON
Bat Cycle Count          normal            35 cycles   --          --          --          --
Bat Learning Active     not_available      --
Bat Pack Invalid         INVALID
Battery Charge          failed             --
Bat_Temp                -17.000 degrees C  cr         0.000     5.000     60.000    75.000
  • 故障日志来自hsamcmd --fault-show-all:
tag  origin  fld                                     fault reason                   count  time
1    0x5     /chassis-1/controller-b/nvbatt-1        Temperature Sensor 92 LNC                       1      Mon Apr 21 05:36:24 2025
2    0x5     /chassis-1/controller-b/nvbatt-1        Temperature Sensor 92 LCR                       1      Mon Apr 21 05:36:24 2025
3    0x5     /chassis-1/controller-b/nvbatt-1        Environmental Condition by env_mgr              1      Mon Apr 21 05:36:24 2025
4    0x5     /chassis-1/controller-b/nvbatt-1        Failed reading sensor: 105                      1      Mon Apr 21 05:36:30 2025
5    0x5     /chassis-1/controller-b/nvbatt-1        Failed reading sensor: 106                      1      Mon Apr 21 05:36:30 2025
6    0x5     /chassis-1/controller-b/nvbatt-1        Failed reading sensor: 233                      1      Mon Apr 21 05:36:30 2025
7    0x5     /chassis-1   SAS Expander has set the Chassis LED ON         1      Mon Apr 21 05:36:30 2025
8    0x5     /chassis-1/controller-b/nvbatt-1        Failed reading sensor: 93                       1     Mon Apr 21 05:36:37 2025
9    0x5     /chassis-1/controller-b/nvbatt-1        Failed reading sensor: 94                       1      Mon Apr 21 05:36:37 2025
10   0x5     /chassis-1/controller-b/nvbatt-1        Failed reading sensor: 97                       1      Mon Apr 21 05:36:37 2025
11   0x5     /chassis-1/controller-b/nvbatt-1        Failed reading sensor: 98                       1      Mon Apr 21 05:36:37 2025
12   0x5     /chassis-1/controller-b/nvbatt-1        Failed reading sensor: 101                      1      Mon Apr 21 05:36:38 2025
  • 事件日志:
Record 2631: Mon Apr 21 05:35:46 2025 [IPMI.notice]: 5502 | 02 | EVT: 0150ef05 | Bat_Temp | Assertion Event, "Lower Non-critical going low "
Record 2632: Mon Apr 21 05:35:46 2025 [IPMI.notice]: 5602 | 02 | EVT: 0152ef00 | Bat_Temp | Assertion Event, "Lower Critical going low "
Record 2633: Mon Apr 21 05:35:46 2025 [IPMI.notice]: 5702 | 02 | EVT: 0301ffff | Bat_Pack_Invalid | Assertion Event, "State Asserted"
Record 2634: Mon Apr 21 05:35:46 2025 [IPMI.notice]: 5802 | 02 | EVT: 0301ffff | Attn_Sensor1 | Assertion Event, "State Asserted"
Record 2635: Mon Apr 21 05:36:00 2025 [IPMI.notice]: 5902 | 02 | EVT: 0300ffff | Attn_Sensor1 | Assertion Event, "State Deasserted"
Record 2636: Mon Apr 21 05:36:18 2025 [IPMI.notice]: 5a02 | 02 | EVT: 81522e00 | Bat_Temp | Deassertion Event, "Lower Critical going low "
Record 2637: Mon Apr 21 05:36:18 2025 [IPMI.notice]: 5b02 | 02 | EVT: 81502e05 | Bat_Temp | Deassertion Event, "Lower Non-critical going low "
Record 2638: Mon Apr 21 05:36:19 2025 [IPMI.notice]: 5c02 | 02 | EVT: 0300ffff | Bat_Pack_Invalid | Assertion Event, "State Deasserted"
Record 2639: Mon Apr 21 05:36:19 2025 [IPMI.notice]: 5d02 | 02 | EVT: 0301ffff | Attn_Sensor1 | Assertion Event, "State Asserted"
Record 2640: Mon Apr 21 05:36:24 2025 [IPMI.notice]: 5e02 | 02 | EVT: 0150ef05 | Bat_Temp | Assertion Event, "Lower Non-critical going low "
Record 2641: Mon Apr 21 05:36:24 2025 [IPMI.notice]: 5f02 | 02 | EVT: 0152ef00 | Bat_Temp | Assertion Event, "Lower Critical going low "
Record 2642: Mon Apr 21 05:36:24 2025 [IPMI.notice]: 6002 | 02 | EVT: 0301ffff | Bat_Pack_Invalid | Assertion Event, "State Asserted"
  • EMS日志:
Mon Apr 21 14:35:57 +0900 [NAP-CL7-02: env_mgr: nvmem.battery.tempLow:alert]: The NVMEM battery is too cold (-17 C). To prevent data loss, the system will shut down in 24 hours.
Mon Apr 21 14:36:25 +0900 [NAP-CL7-02: env_mgr: nvmem.battery.temp.normal:info]: The NVMEM battery temperature is normal.
Mon Apr 21 14:36:25 +0900 [NAP-CL7-02: env_mgr: nvmem.battery.packValid:notice]: A valid NVMEM battery pack is present.
Mon Apr 21 14:36:47 +0900 [NAP-CL7-02: env_mgr: callhome.battery.warning:alert]: Call home for BATTERY (temperature low) WARNING.
DeviceChemistry   : LION
ChemistryID       : 0x0286
DeviceName        : bq40z50-R1
Manufacturer      : Nexergy
FW_Version        : A2
Manufacturer-date : 3/13/2018
GG_HW_RV          : 0x000a
GG_FW_RV          : 0x0045 0x0601 0x2400 0x00 0x8503
StateOfHealth     : 43 %
BatteryMode       : 0x0001
BatteryStatus     : 0x00c0
LrnCycleStartDate : 25-04-10-12:00
LrnCycleStartFCC  : 0x0559
LrnCycleEndFCC    : 0x0545
LrnCycleEndDate   : 25-04-10-17:25
