跳转到主内容
缺少SP HBT时电池电量不足
i
Knowledge Base guidance
This article may include metadata, visibility, validation state, and related support guidance.
适用场景
  • ONTAP 9
  • 服务处理器 (SP)
问题描述
  • EMS报告 BATTERY_LOW。
[node: statd: monitor.nvramLowBattery:critical]: NVRAM battery is dangerously low.
[node: statd: monitor.nvramLowBattery.notice:info]: If the NVRAM battery is dangerously low, the system shuts down automatically every 24 hours to encourage you to replace it. If you reboot the system it will run for another 24 hours before shutting down.
[node: statd: callhome.battery.low:error]: Call home for BATTERY_LOW
[node: statd: monitor.shutdown.nvramLowBattery.pending:warning]: NVRAM battery is dangerously low. Halting system in 24 hours. Replace the battery immediately!
  • SP-LATEST-IPMI 显示电池正常。
Bat_1.5V         | 1.494      | Volts      | ok         | 1.280     | 1.348     | 1.649     | 1.727
Bat_3.0V         | 3.146      | Volts      | ok         | 2.545     | 2.703     | 3.504     | 3.575
Bat_8.0V         | 7.800      | Volts      | ok         | 6.000     | 6.600     | 8.600     | 8.700
Bat_Curr         | 0.000      | Amps       | ok         | na        | na        | 0.800     | 0.900
Bat_Capacity     | 1.792      | Amps * hour | ok         | na        | na        | na        | na
Bat_Run_Time     | 114.000    | hour       | ok         | 76.000    | 78.000    | na        | na
Bat_Temp         | 25.000     | degrees C  | ok         | 0.000     | 10.000    | 55.000    | 64.000
Charger_Curr     | 0.000      | Amps       | ok         | na        | na        | 2.200     | 2.300
Charger_Cycles   | 35.000     | cycles     | ok         | na        | na        | 250.000   | 251.000
Charger_Volt     | 8.200      | Volts      | ok         | na        | na        | 8.600     | 8.700
  • 之后的EMS报告 SP HBT MISSEDBATTERY_LOW。
[node: spsm_listener: sp.heartbeat.stopped:warning]: Have not received a IPMI heartbeat from the Service Processor (SP) in last 20 seconds.
[node: spsm_listener: callhome.sp.hbt.missed:notice]: Call home for SP HBT MISSED
  • 这篇文章对您有帮助吗?
