由于磁盘自动分配配置不当,更换磁盘后,此 LED 呈琥珀色
Knowledge Base guidance
This article may include metadata, visibility, validation state, and related support guidance.
适用于
- 所有 FAS/AFF 平台。
- ONTAP 9
问题
- 更换磁盘后,琥珀色 LED 亮起
- 驱动器报告的故障状态:
cluster::> system node run -node node1 -command storage show fault -v
18 [Bay 18]: OK 01,12,00,20 FAULT REQSTD
