跳转到主内容
AFF A70风扇以高转速运行且声音很大
i
Knowledge Base guidance
This article may include metadata, visibility, validation state, and related support guidance.
适用场景
  • AFF A70
  • ONTAP 9
问题描述
  • 风扇高速运转且声音很大
  • 从SP-IPMI-Latest 可以看出
Sysfan4 F1 Speed     normal     21840 RPM   3120 RPM   4030 RPM  28990 RPM  32500 RPM
Sysfan4 F2 Speed     normal     19110 RPM   3120 RPM   4030 RPM  27950 RPM  31070 RPM
Sysfan5 Status      normal       25      --      --      --      --
Sysfan5 Present             PRESENT
Sysfan5 F1 Speed     normal     21840 RPM   3120 RPM   4030 RPM  28990 RPM  32500 RPM
Sysfan5 F2 Speed     normal     18850 RPM   3120 RPM   4030 RPM  27950 RPM  31070 RPM
Sysfan6 Status      normal       25      --      --      --      --
Sysfan6 Present             PRESENT
IO2 Status        normal       57      --      --      --      --
IO2 25G CX7 Temp     disabled      -- C     0 C     5 C    100 C    105 C    ==>disabled
IO2 25G P1 Temp      disabled      -- C     -5 C     -1 C     70 C     75 C
IO2 25G P2 Temp      disabled      -- C     -5 C     -1 C     70 C     75 C
IO2 25G P3 Temp      disabled      -- C     -5 C     -1 C     70 C     75 C
IO2 25G P4 Temp      disabled      -- C     -5 C     -1 C     70 C     75 C
  • 从上面的部分,请注意 插槽2中卡的传感器不可读,检查sysconfig -a ,我们看到连接了不受支持的电缆
slot 2: Quad 10G/25G Ethernet Controller CX7
e2a MAC Address:   d0:39:ea:bf:e5:57 (auto-unknown-fd-up)
SFP Vendor:     Amphenol
SFP Part Number:   606780010  ===> unsupported cable
SFP Serial Number:  APF15240105FHD
