AFF A700s - 电池出现严重故障
Knowledge Base guidance
This article may include metadata, visibility, validation state, and related support guidance.
适用于
- AFF A700s
问题描述
将显示以下一个或多个消息:
WARNING: The battery is experiencing a critical failure:
- Battery is not present
Without a working battery, the system cannot retain data
during a power outage, which can result in data loss.
Power down the system and verify that the battery is
properly installed.
To ignore this failure and boot the system in a mode
where data loss might occur, press 'c' followed by 'Enter'CAUTION: Using this appliance without NVRAM
battery backup coupled with a power
failure condition CAN CAUSE DATA LOSS.
Are you sure you want to continue (y or n)? y
Proceeding without NVRAM battery backup.
***OS2SP configured successfully***Feb 09 09:07:26 [storage1-netapp-hnd4_1:nv.none:EMERGENCY]: No NV device has been detected.LOADER-A> boot_ontap
Loading X86_64/freebsd/image1/kernel:0x200000/14891680 0x1033aa0/13845536 Entry at 0xffffffff802d6c30
Loading X86_64/freebsd/image1/platform.ko:0x1d68000/3034816 0x204d000/477856 0x20c1aa0/583568
Starting program at 0xffffffff802d6c30
NetApp Data ONTAP 9.4P3
ACPI APIC Table:flags 0x40 flags 0x20Tue Feb 9 09:12:22 GMT [nvram.hw.initFail:CRITICAL]: NVRAM hardware initialization failed: NVRAM10 bq24725 device is not detected.
Tue Feb 9 09:12:22 GMT [nvram.hw.initFail:CRITICAL]: NVRAM hardware initialization failed: NVRAM10 bq40z50 device is not detected.
nvd0:NVMe namespace
nvd0: 122104MB (250069680 512 byte sectors)
nvd1:NVMe namespace
nvd1: 122104MB (250069680 512 byte sectors)
