"接收器信号平均光功率"低
Knowledge Base guidance
This article may include metadata, visibility, validation state, and related support guidance.
适用场景
- AFF8080
- ONTAP 9
问题描述
Receiver signal average optical power被下面的开关命令指示为低电平。
comadmin@switch1> show interfaces descriptions | match 0/0/15xe-0/0/15 up down node1_e0e{master:0}comadmin@switch1> show interfaces diagnostics optics xe-0/0/15 | match dBmLaser output power : 0.5870 mW / -2.31 dBmReceiver signal average optical power : 0.0001 mW / -40.00 dBmcomadmin@switch2> show interfaces descriptions | match 0/0/15xe-0/0/15 up down node1_e0f{master:1}comadmin@switch2> show interfaces diagnostics optics xe-0/0/15 | match dBmLaser output power : 0.6040 mW / -2.19 dBmReceiver signal average optical power : 0.0001 mW / -40.00 dBm- 上述端口在中已关闭
IFGRPS.XML
Node node2 node2
Interface Group Name a0a a0b
Up Ports e0g e0h
Down Ports e0e e0f- 上述端口已在中启动
SYSCONFIG-A
slot 0: 1G/10G Ethernet Controller CNA EP 8324
(Multiple Dual-port, QLogic CNA 8324(8362) rev. 2)
e0h MAC Address: 02:a0:98:b4:87:1f (auto-10g_sr-fd-up)
e0g MAC Address: 02:a0:98:b4:87:20 (auto-10g_sr-fd-up)
e0f MAC Address: 02:a0:98:b4:87:1f (auto-10g_sr-fd-up)
e0e MAC Address: 02:a0:98:b4:87:20 (auto-10g_sr-fd-up)
Device Type: EP8324N
Firmware Version: 5.4.66.0- 系统上可能会显示以下消息
[?] Fri Oct 04 08:14:37 +0000 [node1: kernel: netif.init.failed:alert]: Initialization of network interface e0e failed due to unexpected software error ql:244.[?] Fri Oct 04 08:15:38 +0000 [node1: intr: net.ifgrp.lacp.link.inactive:error]: ifgrp a0a, port e0e has transitioned to an inactive state. The interface group is in a degraded state.[?] Fri Oct 04 08:15:41 +0000 [node1: intr: net.ifgrp.lacp.link.inactive:error]: ifgrp a0b, port e0f has transitioned to an inactive state. The interface group is in a degraded state.
