与远程卷的 E 系列远程镜像通信已关闭
Knowledge Base guidance
This article may include metadata, visibility, validation state, and related support guidance.
适用场景
- E系列
- 异步远程卷镜像(ARVM)
问题描述
Storage Manager在图形用户界面中报告以下错误:
Data could not be loaded from the storage array. One possible cause is the object on which you you were performing the operation no longer exists. Other possible causes include network issues, inability to communicate with the controller, or loss of power to the storage array. Check these causes and then retry the operation.
